scool191
May 12, 2014Explorer
So Confused
I am so confused by all of this. I am looking to buy a new travel trailer. I drive a 2011 Ford F150 Supercrew V6 3.73. Per Ford the max tow weight is 5700 pounds. The trailers I'm looking ...
rbpru wrote:
Westend is correct the max towing is 9800 lbs. with a WD Hitch. It is 5800 without a WD hitch. As also stated, you will most likely run out of cargo capacity before you run out of towing capacity.
