BarneyS wrote:
If you are going to do the liquid roof, then there is no need to remove the air conditioner as long as it is not leaking now. Just use a paint brush and cut in around the bottom of the air conditioner. That is what I did and it came out fine. I did remove all my vent covers though for cutting in and then replaced them before doing the rest of the roof.
Barney
Hrm its not leaking now but I figured it would be good to cover under it still? Though I still see white around it, i assume thats because the rubber is more protected from the sun.
So you did under your vents and then let it cure before replacing? Or you put the vents back on wet and now they are non removable vents?
