mbopp
Dec 22, 2015Explorer
If you look closely you can see 2X6 blocks cut at 45 degrees and stacked as my levelling blocks. What you can't see is the 8" bolt with a point ground on the end. The blocks are drilled through an the bolt is hammered through the blocks and into the ground to keep the blocks from kicking out when i drive up them.
44,029 PostsLatest Activity: Mar 16, 2025
