memtb
Jan 16, 2018Explorer
time2roll wrote:Ductape wrote:My truck goes 175-200 miles max when towing. One fill en-route is usually enough. If that fill took an 60 to 90 minutes I would be OK as the price is under $1 per gallon for equivalent miles. The second fill on the road would be a bit much. However recharging overnight in the campground would be great.memtb wrote:
When: They can tow 20K lbs, with a minimum of 400 miles between charges....and you can re-charge in 15 minutes or less! :)
What about all those Chevies with 26 (?) gallon tanks? ;)
I have been driving an EV since May 2011 and I agree the battery technology can still use some improvement for long distance towing. Day to day use the EV is wonderful. Zero maintenance, just some warranty repairs and tires so far. Repair expenses could make a diesel owner balk but they seem to be infrequent and should come down with higher production.
Re-charging in campgrounds is nice.... unless you boondock. I guess that we will be limited to areas were there are an abundance of “current bushes”! :h
