mowermech
Jan 19, 2014Explorer II
socket sizes
does any body know what size socket is used for the bearing hub retaining bolts on the front axle of a 2001 Dodge 1500 4X4? they are 6 point star shaped "reverse torx" bolt heads, and should be an "E" type socket, E16 or larger. the bolts are torqued to 120 ft. lbs.
How about the big nut on the end of the axle shaft?
I have been searching on google until my eyeballs are tired, and so far I have found that the axle nut is either 1 11/16, or 42 mm or 1 1/8; the hub retaining bolts are either 9/16 or 15 mm 12 point socket.
I would much rather have the proper "reverse torx" E type socket to avoid damaging the bolt heads! I found sets of E sockets at Sears and O'Reilly, but they only go to E16. Lowes had a set that went to E20, but they were 1/4 drive.
I may have to track down the snap-on truck!
Maybe I'll check Harbor Freight first...
