NCMODELAExplorerMar 10, 2014Soft SpotI noticed in the front left pass through storage area that it was wet after a strong rain. I started poking around and the corner (less than 2" square) is soft. The piece of wood that runs across th...Show More
Gene_GinnyExplorerMar 12, 2014I thought I had a leak in a compartment door once but it was the latch that was loose and wasn't closing the door tight.Try putting a worklight inside the compartment at night and close the door. See if there is any light shining out the edges. It is a cheap easy test.
Related ContentSoft spots in floorsUsing pourable epoxy on floor soft spotsfound soft spot in floorForest River Foam Core floor soft spotsSoft spot in floor
