wcjeep
Jul 01, 2014Explorer
rhagfo wrote:
Well the 3500 as a DD is one thing, as a "Family Car" is a bit tougher. I DD my 01 2500 W/Camper package (3500 springs) I feel most bumps in the road, best you can do is put a great set of shocks on it.
On your 2nd Gen, are you running a steering brace? Not as important on the newer trucks. Should have been factory equipment on the 94 - 02.
I've heard good things about Bilsteins. Never ran them. I use the adjustable Rancho 9000's. When empty I run them at level 3 of the 9 settings. When empty, be sure to lower your tire pressure to whatever the door sticker says.
What tires are you running? Softer rubber will usually give a nicer ride with lower lifespan. Avoid high mileage "E" rated tires. The harder compound does not usually perform well in bad weather.
44,060 PostsLatest Activity: Mar 28, 2026
