hedge wrote:
You still have your terms mixed up.
- Converter changes 120v to 12v, It also usually serves as the 12v and 120v distribution point having breakers for the 120v AC and fuses for the 12v DC side. Never seen a converter that doesn't charge the batteries.
- Charge controller is the piece that sits between solar panels and the batteries.
- Inverter takes 12v DC and inverts it to 120V AC, this is not usually an OEM installed piece.
Now I'm really confused. I am following you on your explanation, the reading I have done on the BW 6406 says that it will allow you to run on either 12v or 120v by flipping a switch, but does not charge the batteries when hooked to shore power. Before I get too involved in this things, y'all please correct me in this.
***Tried to attach a picture to help out, but can't figure it out.***
