work2much
Dec 23, 2016Explorer
Yes, a bit confusing. I would leave the solar panel and charge controller per manufacturer design.
If you have solar panels and a charge controller I would try and improve that system to your needs rather than mixing/relying on truck charging and solar charging through one controller. The trickle charge from the truck will just confuse the charge controller.
As far as storage, if it is long term I would just pack the batteries home and maintain them there. If it is short term disconnect the neg lead on both truck and camper. If the storage is outside you could use your solar system to maintain the batteries. Personally I don't like leaving hot DC electrical systems out of my sight for more than a day or two.
