Sam_Spade
Dec 24, 2016Explorer
adamis wrote:
Is there a reason I'm not thinking about for why I wouldn't want to do this?
Yes. The reason IS that you have not analyzed the situation properly.
If a battery is not coming up to a full charge, it is not getting ENOUGH power, not too much.
Do you own a multi-meter ?
I'm gonna have to read your post again; the first time through some parts of it did not make any sense to me.
Edit: It seems like you have two situations to deal with here.
First is the one set of batteries not being charged while going down the road; or that set being worn out so they don't hold a charge.
Then there is keeping both sets topped off while in storage. IF your controller has outputs for two sets AND your panels have sufficient capacity, maybe 100 watts, then that shouldn't be a problem.
These two situations should not be combined into one ......as they have entirely different solutions.
Getting the inputs and outputs straight would help the discussion too.
