theoldwizard1
Dec 24, 2016Explorer II
Sam Spade wrote:adamis wrote:
Back to the reason for my post though is that I need to put a charge controller between the truck and camper batteries.
No you DON'T. A couple of us have been trying to tell you that.
Sam, I respectfully DISAGREE with you !
Modern (anything on the past 10 years or so) vehicle charging system do NOT put out as much voltage as the older ones or at least they do not for very long. The voltage from the alternator is controlled by the PCM. The algorithms used are designed to put the MINIMUM amount of energy back into the starting battery required to re-start the vehicle.
Within 5-15 minutes after starting the voltage will be regulated down to <14V, maybe even <13.5V.
