theoldwizard1
Dec 26, 2016Explorer II
Sam Spade wrote:
Did you intend to add something to the discussion with THIS post ??
Yes.
... The voltage from the alternator is controlled by the PCM. The algorithms used are designed to put the MINIMUM amount of energy back into the starting battery required to re-start the vehicle.
Within 5-15 minutes after starting the voltage (from the vehicle alternator) will be regulated down to <14V, maybe even <13.5V.
You can not properly charge a "house battery" with that low of a voltgae.
(P.S. I have 31 years in designing automotive fuel injection systems which INCLUDES the algorithms to control the voltage regulator.)
