14.5 volts is common and normal charging voltage. Trojan and other call for 14.8 volts.
Usually a controller will hold that voltage based on a timer of 60 to 180 minutes regardless of amps then drop to float around 13.2 to 13.6 volts. Generally when you reach 1/2 of 1% capacity in amps you are full. 225 amp/hours battery would be 1 to 1.5 amps so you are full.
Only way to really control the process is to get a programmable controller.
If you can turn off the equalize function I recommend it. You need to read your manual a bit closer. Maybe switch the setting on battery type.
