westend wrote:
.....until the batteries were at 14.5-.7 and then there was still 1-1.5 amps of charge
Can you explain this more fully? You are stating a voltage and a level of current, two dissimilar things.
The charge controller may be charging the batteries at 14.7 Volts and you may have 1.5 Amp Hours of capacity to fill but that isn't clear from your post.
After the batteries have rested with no charge and no load what is the voltage? The Victron should display that in the early AM before sun hits the panels.
Theoretically, the solar charge controller will charge until the batteries will not accept any current from the solar system. There is always a small amount of self-discharge (along with any parasitic loads) so that state of charge is fleeting.
I have a programmable, temp compensated controller and it is usually back at float level very early in the morning when in storage. It will cycle through the bulk and absorption charge levels quickly before going into float.
More focused advice can be given if you share which controller you have.
He said he has a zamp zs 7a, its only a 2 stage whchis likely the problem.
