egarant's avatar
egarant
Nomad
Nov 24, 2013
Solar Float Charge
I have two DieHard Platinum Marine Group 31 AGM batteries.
Question is, what should be my cut off voltage charge setting in my solar controller?
From what I have gleaned off the Internet, I have it currently set at 14.2 volts.
Sound good?
Mr. E
  • The 12 volt side of life.
    Part 1.
    My controller has a jumper for wet cell at 14.2 and AGM at 14.6.
    There are better controllers available today with secondary load diversions that begin to charge other items when the primary load, house batteries are full. Mine is a 15 year old Hitachi PWM controller that at least has temperature compensation. Our entire solar system could use an upgrade but being that it is installed and working and free, there is no rush other than to add an additional solar panel.
    Right now the TC is plugged in and the Boondocker power supply is putting out a maintenance charge of 13.1-13.2 volts. The 60 watt solar panel is putting out 14.6 volts and .3 amps during the winter. During the summer it will climb to 4 amps. Somewhere between 4 watts winter and 52 watts summer.
    The batteries are working fine under these conditions. We have the PM-1 batteries too.
  • 14.2 may be fine, may be a little high. You would have to look up the charging specs for your particular battery to know for sure.
