Flyfisher86
Jul 10, 2013Explorer
I put two 100w panels on the roof of my NL they run along the edge of the roof next to the AC. The panels I used are made by grape solar and are smaller than the standard 100 w panel. As AidenJ said DO NOT use the luggage rack as per Northern Lite the rack is for decoration not function it only screws into the glass and has no support, as a matter of fact we both removed ours because the screws keep coming loose. What I used to attach the panels was 3m VHB tape holds the panels great,but you must do a good job of cleaning the surface first. You can also use polyurethane construction adhesive which is what we used on AdienJ panels that way no holes are made in the roof. Northern lite recommends using glue also if you do screw the panels down because there is no wood to hold the screws just fiberglass and they could vibrate loose. I cannot post any pictures right now as I am on the road and don't have a good internet connection but will more than gladly post some if you would like when I am able to or send you more info on them. Dave
