bigfootford
Jul 11, 2013Nomad III
VHB tape is great as long as the surface is flat.
When I was in the process of deciding how to mount my panels on the BigFoot I found that my 3x3 aluminum angle stock would not sit flat on my arched top of the camper. Thus I could not use the VHB tape.
So when you get your mounting brackets and have decided to use the VHB tape make sure that the brackets sit flat on the roof.
Also you should use the thin VHB tape. The thin is stronger than the thicker, foam filled tape.
Here is a link to a thread that has pictures of my installation.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24783458/gotomsg/24786385.cfm#24786385
Jim
Jim
