Dakota98
Mar 10, 2015Explorer
pcoplin wrote:Dakota98 wrote:
I wouldn't invest in Solar at this point, IMHO.
Depending if you want to use A/C or not will pretty much determine the size of generator.
I use a Champion 1500/1200 small open frame genny, ( No, it is not loud ) It will run my small microwave in the TT. It's also great in conjunction with a "portable" smart battery charger, in as much as my converter is useless for charging. If the converter in your TC is original, you're in the same boat.
Champion & for $200 you can't beat it. Great customer service, parts are easy to get, & it's very dependable.
Wow, $200 for a 1500 generator? As long as it's similar to the Honda in how quiet it is, I'll order one today.
I don't have AC, it's more to charge the battery up for a little bit during the day when I need it. I may drop a littl emoney on an amp meter for it though.
NOTHING is as quiet as a Honda or Yamaha "INVERTER" type of generator.
But, unless you want to spend $900 - $1000 or more for something that you're not going to use that often ???
My Champion is rated @ 65dBA @ 23'
The Honda 2000 is rated @ 59dBA under load.
Or you can get a CHAMPION 2000 Inverter "Refurb"rated @ 53dBA @ 23' for $375
44,056 PostsLatest Activity: May 04, 2014
