1995brave
Jun 25, 2023Nomad
You are running two 6 volt batteries. They should be wired in series to get 12 volts. So the +VE should go to the positive terminal of the first battery and the -VE should go to the negative terminal of the other battery. There should not be a second +VE connection to the second battery.
