canicon25
Jul 03, 2023Explorer
I went and found the manual for the power converter/charger. It is an Elixir ELX-45. In the specifications section it says DC output is 13.5Volts 45Amps.
It also says "...designed to output a constant voltage of 13.5-13.6 volts at no load and 13.1 volts at full load to ensure trouble free service of all 12volt DC appliances."
Does this mean when plugged into shore with everything turned off the batteries would only be receiving 13.5-13.6VDC max? Kinda sounds that way to me.
