SoonDockin's avatar
SoonDockin
Explorer II
Apr 09, 2022
Solar Panel Mounts
I have an Arctic Fox 1140 with the round roof. I have some 200w panels that are 5ft by 26". I can use the simple z mounts and have the same issue if I ever want to remove them. So I have been considering using 2 4040 aluminum extruded rails mounted with L brackets so its somewhat level. I end up with only 8 8mm screws holding the entire assembly down. Will this be enough?
  • I'm considering 3M VHB tape....Good reviews on solar mounting without drilling..
  • jdc1's avatar
    jdc1
    Explorer II
    Depends on what those screws are attached to.
  • With the low cost of panels and their generally long life, can you see a reason to remove them?
