SoonDockin's avatar
SoonDockin
Explorer II
Apr 09, 2022
Solar Panel Mounts
I have an Arctic Fox 1140 with the round roof. I have some 200w panels that are 5ft by 26". I can use the simple z mounts and have the same issue if I ever want to remove them. So I have been considering using 2 4040 aluminum extruded rails mounted with L brackets so its somewhat level. I end up with only 8 8mm screws holding the entire assembly down. Will this be enough?
