full_mosey wrote:
What happens if you blanket an entire panel in a series or parallel array?
HTH;
John
In parallel you will only kill the production of that panel. For 3 panels, one covered you will still have 2/3 production. In parallel each panel contributes separately. Think of three hoses filling a bucket vs series where the three hoses are connected together with a single discharge into the bucket at a higher psi. The flow is limited by the smallest diameter hose in series where in parallel each hose can fill at their own rate.
