Bearsfanatic85 wrote:
...So I said well couldnt I just get enough to get between 140 to 200 amps, they laughted and said that sure if you dont want to be able to see out the windows!...
I suspect they took you at your word - I assume you meant you wanted 140 to 200 Watts not Amps - at Solar panel voltages 200 Amps would imply 3000+ Watts. I have 2 fairly large solar panels on my camper roof, they are 80 Watts each. To get 200 amps would require 37 of them - hence their joke about not seeing out of the windows :B
Steve.
