First, determine what your power usage might be. Lights, water pump, fan, gas detector, refridgerator, furnace, television, radio, etc. Keep in mind, on a cool night, your furnace could put a heavy drain a single 12 volt battery, and your solar panels give you nothing in the dark. Changing all the light bulbs to LED's, will cut lighting power usage, by about 70 percent.
Approximately 250 watts solar output, 30 amp controller, and a battery bank big enough to handle your power usage. Wire runs should be short as possible and done with 10 - 12 gage stranded copper wire.
What I have:
Two 128 watt (24 volt) panels
Two group 24 batteries
30 amp MPPT controller
The MPPT controller takes up to 48 volt input, and, converts it to 12 volt output.
If you go with PWM controller, your panels must be 12 - 18 volt. Many panels state they are rated at 18 volts, but, actual output is more like 14 volts, which is fine for charging your batteries.
