StirCrazy
Aug 07, 2020Moderator
Lwiddis wrote:
Yes, in the drilled hole, under the bracket and over the bracket.
Mount the controller as close to the batteries as possible in a dry, protected place. A closet seems too small. Dimensions?
What wire sizes are you using?
using 10ga from the panel to the controler as it is only 8 amps and a short run, acording to the charts I can use 10 ga to the bateries also so I might try it and decide if I need to upgrade the clable later.
Steve
