DWeikert
Aug 10, 2020Explorer II
msiminoff wrote:
Hi Steve,
For everything that goes on my TC's roof I use either Dicor or butyl tape under the mounting surface (depends if I expect to remove it or not) and Dicor over the mounting bracket and over the screw heads. I don't personally think that it is necessary to put Dicor inside the screw holes.
Cheers
-Mark
This.
When I upgraded the solar on my Northstar I used a strip of butyl tape under the mounting foot with the screws going through this layer of butyl to seal under the screw heads, then self leveling Dicor over the foot and screw heads.
