StirCrazy's avatar
StirCrazy
Moderator
Aug 06, 2020
solar project starting to come togeather.
Parts have started showing up for me to install solar on my camper.
what I am planing is one 325 watt 120cell split panel on the roof, feeding a Renogy Rover 40 amp solar charge controler feeding two 6V 210Ah lead acid batteries. I ordered the bluetooth modual for it and the tempartue leads you atach to the batteries. I also ordered two 30Amp resetable breakers (one for the panel side and one for the battery side) to act as protection but also a way to disconcect the power to the controler if i have to do any work on the system.
One question I do have is when mounting the solar brackets to the alumium roof, do you put the dicore in the bolt holes and under the mounting feet and then over top when you screw it all in?
and the other big thing is where to mount the charge controler. can I put it in a closet? how hot do they get?
thanks.
Steve
  • I clean rubber roof where mount foot is going, put down eternabond, 2 screws in each mount and I never use Home type sealants on my roof, I use what commercial manufactures use on RV rubber roofs, Dicor to cover the screw heads and to bead the bracket edge down to eternabond.
  • I never use Dicor. I use commercial grade caulk, Sikaflex.
    What kind of truck camper do you have?
  • Yes, in the drilled hole, under the bracket and over the bracket.
    Mount the controller as close to the batteries as possible in a dry, protected place. A closet seems too small. Dimensions?
    What wire sizes are you using?
