Used the same breaker for the fridge and inverter because both are never on at the same time.
There are two relays in parallel, both rated at 40A. It was part of an aux switch package ordered with the truck.
Didn't worry about fusing the separate wires because the run to the connector is only a few inches. Have thought about changing from the 7-pin to a
Anderson SB175 for the power, but didn't like the idea of two connections. Will re-evaluate the fire risk.
To the moderator - move if you wish. However, most times in the tech forum they start talking about 400+ watt systems, not the small demands of a TC. Plus, I know the folks on this board and trust their opinions more.
