itsjustjer
Dec 28, 2018Explorer
Thank you all so much for weighing in. Doing the caravan isn't something that crossed my mind. It certainly might be an option for the shorter trips. I could leave early to set up camp and then they would all come out when it's done. On the flip side, riding 6 in a crew cab is bearable for shorter trips as well.
I looked a little closer at the Expedition Max (and EL). This is a half-ton, correct? It just feels scary to me to pull something substantial with a half-ton.
I found a 2012 Suburban 2500 (VIN: 1GNWKLEG0CR243634). I'm sure this isn't the most reliable way, but I put that VIN into a VIN decoder on the chevy forums website and it had pretty impressive stats (minus the mpg)
If those stats are correct (and I understand them), does this mean I could tow about 8,000 lbs?
1,000 lbs of people/cargo + 1,000 lbs of hitch weight (12.5%) is 2,000 lbs of 2,181 lbs max payload.
6,419 lbs of vehicle curb weight plus 8,000 lbs of trailer weight is Gross Combined weight of 14,419 lbs of 16,000 lbs max.
- Gross Axle Wt Rating - Front 4180 lbs 4180.0 min 4180.0 max
- Gross Axle Wt Rating - Rear 5500 lbs 5500.0 min 5500.0 max
- Curb Weight - Front 3338 lbs 3338.0 min 3338.0 max
- Curb Weight - Rear 3081 lbs 3081.0 min 3081.0 max
- Gross Vehicle Weight Rating Cap 8600 lbs 8600.0 min 8600.0 max
- Fuel Economy Est-Combined 12 MPG 12.0 min 12.0 max
- EPA Fuel Economy Est - City 10 MPG 10.0 min 10.0 max
- EPA Fuel Economy Est - Hwy 15 MPG 15.0 min 15.0 max
- Gross Combined Wt Rating 16,000 lbs
- Dead Weight Hitch - Max Trailer Wt. 5000 lbs 5000.0 min 5000.0 max
- Dead Weight Hitch - Max Tongue Wt. 500 lbs 500.0 min 500.0 max
- Wt Distributing Hitch - Max Trailer Wt. 9400 lbs 9400.0 min 9400.0 max
- Wt Distributing Hitch - Max Tongue Wt. 1410 lbs 1410.0 min 1410.0 max
44,066 PostsLatest Activity: Apr 16, 2026
