ezrydrs's avatar
ezrydrs
Solenoid valve for freshwater tank?
Has anyone tried one of these for a dump valve on the fresh water tank? My current valve is really hard to reach and these 12v solenoid operated valves can be had for about $25. It is a normally closed valve that would be turned on to empty the tank.
Valve
  • I would consider some kind of timing circuit to shut it off after an hour. At 3 amps if you go off and forget(wonder why I think this way) the batteries won't like you if your not plugged into shore power.
  • Vulcan Rider wrote:
    RoyB wrote:
    Sitting here wondering about what the CONTROL SWITCH PANEL LABEL would be named especially for the BLACK WATER TANKS..
    I think you misunderstand.
    This particular valve is NOT appropriate for emptying holding tanks of USED water; only the fresh water tank.
    Yeah... you would need a bigger valve for the poop dump!!! LOL
    Could you even imagine a trailer driving down the road when suddenly a poop dump solenoid opens.....
    Sounds like a great idea for the fresh tank!
    Valve
    Excellent idea. I use the same valve body only with either a 120v or 208v solenoid in HVAC applications. Don't expect it to drain fast, it won't have a lot of flow with only head pressure.
  • RoyB's avatar
    RoyB
    Explorer II
    Might get pushed by some inquiring passenger seeing something named "POOPER SWITCH" hehe...
  • Yes I have used them, they work great, reliable, no problem.
