- SFVdaveExplorerSomeone on the Forester Forum finally came up with the location. Thanks!
Look in the rear driver's side bin; you will see the back wall is actually a lift up door. Drain valves are in there. - SFVdaveExplorerI see DAS beat me to it. Yes please reply as there are others with the same issue.
- DAS26milesExplorer IITry this. turn the winterizing switch to all positions and see if that drains the tank. Please reply with your results. Got this from the Forest River Forum.
- Markiemark32Explorer
- cencerritaExplorer IIHave you looked at the water tank (mine is under the end of the queen bed in a Four Winds Majestic 27G). The valve is on the end of the tank and drains down directly under the RV, so you have to lift up the mattress and take the wooden cover off for access - bad design! Just about to modify the bed surround for a access hole to get my hand in to make things easy next winter.
- Snowman9000ExplorerIs there a blue water line next to the water filter? Dropping through to the underside of MH? If so, is there a valve in it?
- tobydadExplorerSome models have the drain valve on the outside wall of the camper sticking out like a small spigot. It would be on the side near the water tank's location. Others have them on a line leaving the water tank before the water pump. Hope this helps.
38,771 PostsLatest Activity: Apr 19, 2026
