talotto's avatar
talotto
Freshwater Drain Valve Leak
I have a leaking freshwater drain valve. It started out as an occasional drip, now is a fairly steady small leak and will drain 100 gallons or so of water within a couple days. Has anyone ever fixed/replaced one? Where can I get the part(s)? How difficult is it to access (I assume from underneath the coach)?
My rig is a 2004 Itasca Meridian 36G - it's essentially the same coach as the Winnebago Journey.
Thanks in advance for any advice you can provide.
Tony
  • I have one that will drip if I close to the stop. If after hitting the stop, I back it off just a tad, I get no drip. Been working that way for years.
  • Location of valve.....that should be easy to find. Look for wet spot on ground.
    Type of valve.......either a 1/2" Flair-it or 1/2" Sharkbite/Gatorbite
    Flair-It is a compression screw on type valve
    Sharkbite/Gatorbite are a push/snap on type valve (more expensive)
    Sharkbite--Home Depot
    Gatorbie---Lowes
    Difficulty.....depends on access to valve. Valve is probably installed with a PEX crimp so the crimp band will need to be cut off to remove valve.
    IF using a 'bite' type valve.....just cut PEX pipe in too (Clean/straight cut) cause the 'bite' type valves need a smooth pipe to seal
  • The valve can probably be replaced with a standard plumbing ball valve from the hardware store but I have no idea what you have. Got a picture?
  • changing a valve is eaay drain tank , and take it apart. if your not handy .find a friend that can do it. its not a hard job.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
