- LarryJMExplorer II
Midnightpumpkin wrote:
Why not just put the ball in the socket on the trailer hitch and clamp in in place just like when you are towing. Put a padlock on it so no-one messes around and drops it on thier toes.
The greasy ball is covered and you can rotate the hitch so it is out of the way.
John U
Glad you can lift that 40+lb unwieldly, unbalanced drawbar-hitch head with one hand and align it into the tongue socket while latching it in with the other hand. I know I couldn't do that without a second person or a floor jack.
I now just stand mine up on end with the drawbar pointed up with the ball towards/under the A-Frame and lock it to one of the safety chains with my Reese locking hitch pin. I do like the receiver idea, but not how it might stick out from the A-frame due to my extended drawbar (approx 18").
Larry
Might be a problem when I get older, I am only 71 now. It is all in the technique you use.
John U
SECRET TECHNIQUES only known to you and obviously not wanting to share to me means it's not as easy as being portrayed. If you have developed a physics defying method you should copyright it and become a millionaire:R
OTOH to me it says you have never done what you have portrayed as simple and easy.
Larry - MidnightpumpkinExplorer
John U
Larry
John U - LarryJMExplorer II
John U
Larry - NorthTrail23ExplorerThat IS awesome - great idea. Thanks!
- hohenwald48Explorer
John U
That's the way I do it. Plain and simple. - aguablancoExplorer
John U
There's always one.
RichH - MidnightpumpkinExplorerWhy not just put the ball in the socket on the trailer hitch and clamp in in place just like when you are towing. Put a padlock on it so no-one messes around and drops it on thier toes.
John U - notevenExplorer III... And it can be locked to the trailer...
thanks for posting images - gboppExplorerWow! Simple and effective. :C
The RV builders should offer that, at least as an option.
Thanks for posting. - WOW, that is an awesome idea. When I had a bumper pull toy hauler, I always unhooked, and removed the hitch, and chucked it on the ground. Then it would rain, and get the hitch all nasty.
I now have a truck camper, and a big enclosed trailer. I could easily benefit from this on the enclosed trailer.
44,056 PostsLatest Activity: Jan 01, 2026
