I used Dicor 901BA when I replaced our roof, It is water based, (water borne more accurate) more of emulsion. Dried its like rubber cement, working with it was also similar to using cement. I have half a gallon left-not any real info on it but commercial package. Slop on side of can is still semi soft and sticky-water wont dissolve it. I could see it losing its bond on wood fibers, if you could get it wet enough to break down the wood. Doesnt sound like fun...
Im only judging by when I removed ours, the membrane was for the most part still adhered, so seperating it stretched not uniformly in its layers. Left it puckered. Will the pieces pull off?
