Farmerkev wrote:
D.E.Bishop wrote:
I disagree with needing 120volt three way switches. I have two switches for my water pump, one in the bath and one in the kitchen next to the water heater switch. My switches are std RV switches by Sigma and they are available through RV dealers and other parts houses. I'll post the numbers and mfgs in AM> DW is calling.
Same as you but my old motorhome has 3.
Bath, kitchen and basement compartment by the outdoor shower and dump valves.
That is because we have a latching controller
http://www.slesolar.com/items/item1261.htm
2 switches can work pretty well in Bishop's setup because you would always be within one toggle of having both switches in the same position. 3 switches without a latching controller and you would be running around trying to find the one switch that was out of alignment with the other two all the time.
I personally wouldn't go through the effort of even adding a second switch just to get the location out of the bathroom.
