2012Coleman's avatar
2012Coleman
Explorer II
Jun 11, 2014
Something is Beeping
Went home for lunch today and heard intermittent beeps coming from my TT. This has happened before and of course it was the low battery alarm on the smoke alarm. I came to the storage lot I used to have it parked at this past winter, and heard the same beeps, so I took out the battery and no more beeping.
Today was a little different. I removed the battery from the smoke detector and turned to leave and before I could get out of the door - BEEP! I thought that was funny as I didn't think these ran off the TT's power, so I shut of the breaker on my 30 amp service and waited. Not too much later - BEEP! But the difference is, while it was parked in storage, the battery was out - it's in and connected now.
So I looked at the CO2 dector and it was still blinking. It is under the dinette, so I tried to remove the cover and could not - not even sure it comes off. I did think that this ran on the TT's power - maybe it still was as I stated before, I have the battery connected. Could not read the manual as I had to get back to work. I could not see the writing on the front as it was low light and I'm to old to read small print without glasses.
Does the CO2 detector use a 9V battery or does it run on the TT's power? If no battery, why would it be beeping? Propane is off. Have not had to mess with it, but have replaced the smoke dector battery several times. Its a newer model - 2012 Coleman, I'm sure that was obvious... Will take a closer look when I return this afternoon, but it was on my mind. Thanks...
