ken56 wrote:
We use a Vornado also and find it to be most adequate. You can't beat how quiet it is and it moves a lot of air for a small heater. Right now I'm heating a 224 sq.ft. addition with it until I get the mini split system going and it is doing great. It was 18 the other night and it kept it at 65 just fine.
1500W IS 1500W worth of heat, doesn't matter the brand (vornado et all)or type (Oil vs fan vs ceramic).
1500W of heat with a fan pushing it can end up making you feel colder the further you are away from it due to cooler temperature of the forced air making it feel drafty.
1500W of heat from the oil filled heats up slow and will be really toasty around the heater.
Your choice, pick your poison but 1500W is 1500W and that is not changing..
The only thing the OP or anyone else can do is ADD a SECOND 1500W electric heater to the mix, but with only 30A (3600W) of electric available something must go. Going to be hard pressed to run 3000W off of 3600W of shore power capacity continually without popping the 30A main breaker!
Might be able to squeak by setting one heater to 750W if available but otherwise one will need to run an extra extension cord to the campground shore power in addition to the 30A cord..
Additionally, 1500W is roughly 5,000 BTU, small RVs typically will have 18,000 BTU furnace and larger RVs can have 30,000 BTU furnace..
5,000 BTU of heat out of one heater is a LONG, LONG stretch for heating an entire RV when considering it is a fraction of the heat a RV furnace can put out..
