Frankly's avatar
Frankly
Spare Tire Mounted Bike Rack
With a new Trailer I have a common problem of bikes. We like to have them, but where to stow them is the question? I immediately gravitated to the rear of the trailer to install a rack off of the bumper, but I see a lot of negative posts on the idea. I have a spare tire mounted to the back wall of TT and am wondering if attaching a rack to this is advisable? I have not looked at how strong the attachment is. Wondering if is even worth a look?
  • From what I have read, the metal the bumper is made of is so thin, it will actually rip under the stress. The weld is still in place and the bumper peels off like a beer can.
    I put the 4 square reinforcing brackets on mine, and then used the bike rack that has 4 separate mounts ( 2 at each side of the back of the trailer ).
    S jumped up and down on each one as hard as I could, and I'm 225, no problems.
    That said, when I put 75 lbs of bikes on it, I also strap everything so tight it can't even wiggle, and then strap to the spare tire for added safety.
    It's still a gamble, but a lot safer than some of the stuff I see on the road.
    https://www.amazon.com/4SQUARE-SafetyStruts-Prevent-Bumper-Failure/dp/B00JASCNEE
    http://www.etrailer.com/dept-pg-RV_and_Motorhome_Bike_Racks-sf-Platform_Rack.aspx
  • I would worry more about mounting to back wall than to the bumper.
    if you bend the bumper it's not as bad as pulling the back wall out.
