dave54
May 05, 2022Nomad
JRscooby wrote:
Off topic, but kind of related; Spare tire on TV. Most people at least look at tires on the ground every day but often do not check the spare. I always air my spare up to max sidewall on the theory it is more likely to have enough when I need it. Yes, I have a compressor, can air up spare. But it is quicker to reduce pressure and over inflated is safer than under inflated.
SOP with me.
After every trip I crawl underneath with a mechanics mirror and flashlight, looking for anything amiss (stick or branch wedged up somewhere, chunk of mud, loose nuts, wear spot on wiring or piping, etc. Check pressure while under there. A cheap Walmart yoga mat saves your clothes and back from the inevitable thorns and sharp rocks on the ground.
I also do not wait until the day of departure from a campsite to check underneath. I check it the first morning there. Then I have several days to fix any problem rather than have my itinerary delayed from a problem discovered on day of departure.
44,029 PostsLatest Activity: Mar 16, 2025
