JIMNLIN
Aug 19, 2019Explorer III
op wrote:
Am I worrying over nothing?
JMO but your worrying over a non issue.
Having owned as many as eight trailers at a time (non rv) with five on the road daily (28 tires on the road) many never had the same tire brand or size or load range spare tire. However they were all close to the same diameter and load capacity.
The only down side I found was in a different tread pattern...or load range....or tire diameter on the same axle could cause uneven braking on that axle especially on wet pavement. Usually causing one tire to lose traction.
When I buy new tires for a tandem axle trailer I buy 4.....or 6 for my triaxle trailers. JMO but buying a new tire that may never see the road was a waste of my hard earned money.
I use LT tires so most trailers spare tires saw little road use. I look at a spare as a tire to get me back on the road to the nearest tire dealer to fix or replace the flat tire.
The Endurance and Carlisle HD both are new tires from their MFG and have been out just over two years. Both seem to have about the same service record (good) so I wouldn't say one in better than the other.
44,056 PostsLatest Activity: May 04, 2014
