Acdii wrote:
Chuck_thehammer wrote:
westend wrote:
I'm still hoping for a creative idea. I might just mount the spare under the tongue. I have to do some work on there, anyway to mount my Equalizer brackets.
Does anyone know a good place to buy a truck mount bracket system, the one that mounts under the bed?
When I return from Michigan... I plan to visit a few Wrecking yards (junk yards) for pickup truck spare tire mount with cable wench.
a couple of "L" channel and a few holes drilled.. Done.
I can NOT weld... even went to night school for it. I suck.
but I can drill holes an install bolts.
If you do, stay away from 03-09 GM ones. They tend to get stuck and you can't lower them without surgery. They use two different metals, which causes bi-metal corrosion, and have a safety lock that is engaged using aluminum. How do I know this, had one, had a flat on a rainy day. Tire dropped 2", cable came all the way down, but the safety lock did its job, a bit too well. Had to have it towed home, then I was able to get the bumper off to reach the mechanism and get the tire off.
I just got a TT and the spare is loaded in the rear compartment. I haven't decided if I want to keep it there or move it to a mount somewhere.
that is very useful information... Thank You.
