Bamaman11
Feb 27, 2015Explorer
BFL13: You seem like you have more than the limited skills to change LS engine plugs.
You should just change the spark plugs and take carb. cleaner and clean the throttle body butterfly and throat while your under the hood.
Drive your vehicle and see how it runs. If the wires and/or a coil are not good, you'll get a trouble code that tells you which cylinder needs attention.
44,056 PostsLatest Activity: Nov 19, 2013
