dmullen wrote:
BurbMan wrote:
CLICKY
That should be easy to install and would cover the hole and look good too! Just need to figure out where to mount the switch, somewhere by the stereo would be easy. Just tap into the 12v feed for the stereo and it's done.
Great idea, thanks! Would I be safer using the speaker wires as a pull string to get different wires to the lights or just stick with the factory speaker wires?
Depends on the size of the wire they ran from the factory, and how they routed it. Won't really be able to make that call until you get in there and see what they ran, and determine if using them as a pull is even possible (likely not if they are stapled anywhere along their length)
