Most speakers are mounted under the awning, and with the awning out any light shining up will be reflected by the white underside of the awning giving you better overall area lighting.
dmullen' wrote:
Great idea, thanks! Would I be safer using the speaker wires as a pull string to get different wires to the lights or just stick with the factory speaker wires?
The speaker wires are going to be 16 or 18 gauge, but if you are running LEDs they won't draw much current anyway. To be safe, add a 5a fuse on the hot leg before the switch. You won't be able to use the existing wires to pull new ones, they are bundled/taped/stapled at various points inside the walls and ceiling.
