- BedlamModeratorThe way I have understood it is there is a primary and secondary and the secondary is only electrically engaged based on current draw rather than running all the time. I do not believe the secondary functions in a fail over mode. Typically they are identical, so you could physically swap them.
- zcookiemonstarExplorerIf you get dual alternators and one of them goes bad does the other one still charge? The electrical systems on these newer vehicles is strange it would not surprise me if one alternator died the system would see a problem and shut down the whole charging system. Not saying this is a reason not to get them but if one still works if the other dies it would be nice.
- valhalla360Navigator
travelnutz wrote:
The thread OP is from/living in the Midwest where solar is very iffy at best and there's trees everywhere too which virtually block out the sun's rays anyway. Note that the promotors of solar are from the desert/bleak/virtually treeless areas of North America. We know the difference as that's where we live in the Midwest also and very smartly opted for dual alternators on our ordered diesel truck and been so happy we did.
Remember that the alternator works equally fast in recharging in any area/location you might be in unlike with iffy solar. Alternators are not affected by cold, altitude, clouds or trees, rain or snow, and is very fast and dependable.
We had solar on our boat in Michigan and it put out fine. Yeah, if you are in dense woods it won't do much but more often than not in Michigan, we have a decent amount of sun.
The big advantage is if you aren't moving daily, you still get charging with no fuss. - valhalla360NavigatorAnother issue...even if you spend a few hundred extra to install massive charging cables back to the camper...unless it's a massive battery bank, the batteries won't absorb 400amp.
The max charge rate is around 25% of the amp-hr rating, so to absorb 400 amps, you would need around 1600amp-hr of battery...and even then once you get up around 80-90%, they will absorb less. - new2this44ExplorerGood information in here. I appreciate it folks.
- Ron3rdExplorer III
camp-n-family wrote:
I went with the larger 220amp alternator option. It’s only a $50 upgrade from the factory and it’s more than sufficient to quickly charge both batteries.
X2. That's what I did - theoldwizard1Explorer II
NRALIFR wrote:
GeoBoy wrote:
If you don’t have solar installed get it installed. Great way to keep the batteries charged while traveling.
Solar is good until the sun sets. You can also harvest more amp-hours from the truck than any solar install on a TC roof. One of the reasons I choose the Redarc DC-DC charger is because it has a built-in MPPT solar controller, and the unit will always take as much power from the Solar input as it can before supplementing that power, up to the maximum rated output, from Vehicle power input. Best of both worlds. :):)
Sounds like an EXCELLENT solution !
OP - stay with the largest SINGLE alternator you can get and put the money you saved into something like NRALIFR suggested. - pianotunaNomad IIIShocking from a solar advocate. Buy a Harbor freight 3500 watt inverter generator with electric start instead of playing with alternators.
Next choice would be dc to dc charging. - KD4UPLExplorer IIOn a brand new truck that's likely $50,000 plus what's another $400? I'd get the duals for sure.
Now, will it help charge your camper batteries? Not without significantly larger wire feeding them thru a separate Anderson style connector or one like used for tractor trailer lift gates. If you're going to be putting hundreds of AHs of battery in the camper/truck I would upgrade the wiring to match.
For my use I typically have stereo amplifiers, amateur radios, inverters, etc. along with the RV. I will absolutely be getting dual alternators on my next new truck. Cummins12V98 wrote:
Yes and more commonly needed on a chassis to build an ambulance or similar.
I thought I wanted dual Alternators but the sales manager said it was more if I snow plowed.
