RamTX
Jun 30, 2013Explorer
Lynnmor wrote:
There should be splines just behind the bolt head. If the bolt turned and rounded the splines, it will always move and won't stay tight. When installing, you must hold the bolt head while tightening the nut. If the hanger is already rounded out, you may be able to flip the bolt to get good engagement on the opposite side.
I doubt very seriously if they would have a splined bolt like you need. You could get a grade 8 bolt in probably the right size, but not a splined bolt like you need! As others have said, go to a trailer parts store that carries suspension parts.
44,071 PostsLatest Activity: Aug 30, 2026
