69_Avion
Jun 30, 2013Explorer
Once you get the tension off of it you will probably have to drive it out with a proper size drift pin. Hopefully, the splines are still holding the bolt from turning. I'll bet that they are. If not, I used to tack them in place. It is an easy fix either way. The splines are there so that the equalizer turns on the bolt and the bolt doesn't turn inside the mount.
44,071 PostsLatest Activity: Aug 30, 2026
