opnspaces
Jun 30, 2013Navigator III
Jack up the frame until the pressure is relieved from the equalizers (the linkages hooked to the springs on either side of the bolt) Then use a hammer and drift pin or punch to drive the bolt out. Replace with a new splined bolt and drive the head in until it's seated in the hole. Do not turn the bolt head as you will strip the splines. Only turn the nut to tighten or loosen the bolt.
44,071 PostsLatest Activity: Aug 30, 2026
