Anyone have any ideas why my oem clutch started squeaking when my foot presses down? The truck is a 2004.5 with the nv5600 transmission. It has a 148000 miles on it and the clutch still works.
And you need to replace the clutch assembly (clutch disk, pressure plate, and throw out bearing at minimum. Maybe even the flywheel too if it’s a dual-mass type) before the bearing comes apart. If that happens, you’re stuck waiting for a tow. BTDT.
